Specific wifi problem, on printer side, not slicer
Vic
 Vic
(@vic-2)
I’ve installed the hardware and updated the firmware.  I followed the directions on on setting up wifi for the Mini+, and it works fine.  I’ve been able to print several items straight from Prusa slicer, upload to the USB drive on the Mini+, and it all worked.
The issue comes up after I turn off the printer and turn it on for the next day.  Seems like the printer loses all wifi settings.  I re applied the setting ONLY to the printer (I did NOT need to touch the slicer) and it works fine.  Exact same API key, exact same IP address (I made it static anyways).  Once I re do the printer side of the wifi, it works again.  When I turn off the printer, it forgets everything.
Any advice?
Opublikowany : 07/03/2023 2:36 am
Vic
 Vic
(@vic-2)
RE: Specific wifi problem, on printer side, not slicer
More trouble shooting, it's not the printer or the software.  Its Ubiquiti.  Logged on to the AP and forced reconnect.  Worked.
I really have no idea why its doing that.
Opublikowany : 07/03/2023 10:36 pm
