Spare Parts and Accessories
Someone knows when the spare parts will be available in the store?
Can I buy the E3D nozzle's from store for the MINI?
RE: Spare Parts and Accessories
I am informed that spare parts will be in the shop early next week.
The standard E3D nozzle also works with the mini.
If you need any spares, contact support via the shop "Chat". They should be able to help.
Peter
Here you are, but still missing some parts like rods etc.
all I get when following your URL is:
There is 1 error
- You do not have access to this category.
Mini with FW:4.4.1 + SuperPINDA + Bondtech Heatbreak + PC4-M8 couplers + 1 piece boden
Someone said something about its only visible for people who already received their mini. It would be great to add some stuff to the order instead of creating a new one with additional 10-15 bucks shipping cost.
Could you maybe add a Screenshot of the available items? Have 4 additional items in my cart atm, so maybe I can decide to wait with my next order ^^
Itâs better to give than to receive. Especially advice.
Agreed, that is why I wanted to know for sure -- I also want to add stuff to my order.
Hi guys,
feedback noted, I will see, what can be done to make the parts visible for all of you.
Well, I can see them (spare parts for MINI), but still waiting to delivery of my 2 ordered MINIs. I don't want to post here screenshots, when it is only for owners. But there are almost all parts except rods.
FYI, no it does not worth it to build MINI from spare parts due to fact, that the entire machine costs less then spare parts in total.
I logged out and back in again and on the above URL I still get the error message.
OK, here are the list of spare parts for MINI so far:
Assembled hotend MINI
Bearing 625 2Z
Bearing housing 623h
Buddy control board
Filament sensor MINI (assembly)
Hotend fan MINI
Hotend heater cartridge E3D 24V 40W
Hotend thermistor E3D
LCD panel orange / black (assembly)
MINDA probe
MINI Double-sided Textured PEI Powder-coated Spring Steel Sheet
MINI Spring Steel Sheet With Smooth Double-sided PEI
Magnetic heatbed MINI 24V (assembly)
PSU
Print fan MINI
Pulley GT2-16
Stepper motor E-axis Extruder
Stepper motor X-axis
Stepper motor Y-axis
Stepper motor Z-axis
U-bolts
and a lot of plastic parts
thank you
OK, so the nozzles may, or may not be, the same as used for the mk3/s, but they are not tagged as such right currently.
Texy
@texy
It is hard to keep all description up to date. E3D nozzle is compatible.
There is 1 error
I also get this error, though I have already received the printer 😕
