Something wrong with hotend and temperature
Killmyday
(@killmyday)
Suddenly when I attempt a print nothing gets printed.
If I go to Purge nothing comes out the nozzle, but if I go into settings and heat the nozzle head to 280 and eminently go to Purge it comes out just fine.
If I attempt a calibration test same thing, after a preheat it goes some what ok, but second try nothing get's out??
Any suggestions would be appreciated.
Napsal : 07/08/2021 10:39 pm
Aint half hot round here
Is the extruder temperature above 170C?
there is a low temperature extrusion prevention temperature set at 170C
Joan
Napsal : 07/08/2021 10:46 pm
Killmyday
(@killmyday)
No its 215 degrees
When it attempts to either print or purge it's 215
Napsal : 07/08/2021 10:53 pm
Odd behaviour.
Hi.
I don't have a mini myself.
could you please  unload the filament and see if there is a section chewed out by the extruder drive gear?
then could you disconnect the PTFE bowden tube from the extruder, reload the filament, and ensure that the filament extends beyond the end of the PTFE Tube, if it does, then without refitting the PTFE tube, start a job and see if the filament feeds through the ptfe tube as you would normally expect for printing? this should show you, whether the issue is extruder related or hot end related.
If the filament feeds as expected, check that your hot end liner PTFE is in good condition and that the hot end is correctly assembled, some mini's were supplied with short Hot end PTFE tubes, and some Mini hotends were incorrectly assembled with the heatbreak tube extended too far.
If you have to adjust anything in the hotend. please re adjust the Pinda (Spinda) height, and re run Live Z calibration.
Napsal : 07/08/2021 11:10 pm
Killmyday
(@killmyday)
Found the error
It turned out it was the thermistor that was faulty, ordered a new one.
I think it happened when I was changing the Nozzle to a steel one, it's quite sensitive right?.
Napsal : 08/08/2021 9:13 pm
Thermistors are fragile
thermistor wires are very flimsy
did you order two... one for now and one for next time!
Joan
Napsal : 08/08/2021 10:25 pm
Killmyday
(@killmyday)
Actually
I ordered 2 and a complete head end, just to be sure.
Napsal : 08/08/2021 10:46 pm
Hotends
Posted by: @killmyday
That is a safe way to go.
Napsal : 08/08/2021 10:57 pm
