Something isn't right here.... :')
Billy.das
(@billy-das)
Im at a loss for words
Top left is at 0.366
Top Right is at 0.381
Bottom left is 0.516
bottom right is -0.093
HOW can this be SOOO off????
i have had this print for 2 weeks... and this is only recent.
Its on a flat surface and has all 5 of those rubber pads on the base of the printer (4 on the printing area and 1 on the box with the mobo)
What on earth.... what do i do at this point
Opublikowany : 16/11/2020 7:32 am
Crawlerin
(@crawlerin)
RE: Something isn't right here.... :')
I'd take a look on whether X is parallel to bed surface. Make sure your XZ part is mounted as perpendicular as possible to Y extrusion, both ways (take some machinist square, loosen those 3 screws a bit, then tighten screws with square tool attached). Adjust further according to this guide: https://help.prusa3d.com/en/article/xz-axis-skew-correction-mini_158518
Opublikowany : 16/11/2020 2:29 pm
1 ludzie polubili
Billy.das
(@billy-das)
@crawlerin
Thanks, so after some further investigation,  i got my square and put it parallel onto the bed, it seems my bed is warped in 2 places, so im looking into using the silicone mod to try level it out within the next 3 weeks
Opublikowany : 18/11/2020 12:02 pm
remotelove
(@remotelove)
It's crazy how MBL is able to compensate for this, actually. I just tuned my X as well, so am going to take another bed map and sand down washers to do any additional major correction. There is still a big sag in the front left of my bed that MBL can almost fix, but can't..
All things considered this is an easy fix. On my Enders, I had to get a large sheet of glass, glue sandpaper to it and manually grind the beds down to get them proper.
Opublikowany : 21/11/2020 4:15 am
