Smooth PEI sheet print marks not going?
Robeena Shepherd
(@robeena-shepherd)
Respondido : 18/03/2020 8:02 pm
Robeena Shepherd
(@robeena-shepherd)
RE: Smooth PEI sheet print marks not going?
Arg I lost my edit! You don't get long to edit do you. 🙁
Okay trying again... the short, short, short version #Spaceballs.
Had mini for a month, sheet shows marks from calibration, nothing gets rid of the marks. Also having first layer problems that I didn't have for the first two and a half weeks. Cleaned it with IPA 99%, also tried acetone when that didn't help, and finally dish soap followed by the other two in reverse order.
Marks don't go away. 🙁
If I print at 30% speed for the first layer, with Prusament PLA, and then go back to 100% everything is perfect. But if I print at 100%, perimeter lines barely stick at all.
I'm wondering if the marks not coming off and the layer adhesion are related.
Is anyone else experiencing this? Feels a little low on use to need a new PEI sheet.
Respondido : 18/03/2020 8:14 pm
A lot of those sorts of things may go away with time as you print over it. I have a sheet that had marks from a Live-Z adjustment that was way too low. Over time, those marks are less obvious, and of course new dings and scratches have been added. If they really bother you, try something like a 3M 7445 ScotchBite pad. These are the low abrasion types used for polishing glass & chrome, not kitchen scrubbers! Back in 2018, such a scuffing was recommended for cleaning badly fouled PEI, though Prusa seems to be removing that recommendation, so use at your own risk.
Otherwise, don't worry about it. The bed gets used and shows it. Shouldn't adversely impact your prints.
As for Live-Z, I don't have a Mini so can't help with specifics. Look around for other threads discussing Live-Z issues. I've seen a couple.
Respondido : 18/03/2020 9:36 pm
1 les gusta
Robeena Shepherd
(@robeena-shepherd)
Thank you, I will try really hard not to let my OCD take over and force me to scrub it, and tell myself it doesn't matter over and over. 🙂
I thought my Live-Z was calibrated properly, I'm printing now with the sheet that I thoroughly cleaned using Eryone Sparkly Black and it's fine at 100% in the Tune menu, but Prusament PLAs Lipstick Red and Banana Yellow have both needed to go down to 30% for the first layer to stick properly. :/
An example below of something I had to abandon:
This is partway through the second layer. The next one is the first layer. Maybe I just need to be more aggressive with the Live-Z?
30% speed and it worked just fine.
Esta publicación ha sido modificada el hace 6 years por Robeena Shepherd
Respondido : 18/03/2020 10:07 pm
Robeena Shepherd
(@robeena-shepherd)
Oh I found your notes from Googling in the first week of getting my Mini I've read lots of them, they are awesome, thank you so much for publishing these! They've been really helpful as I've been learning. 🤗
Respondido : 18/03/2020 10:10 pm
Oxygen
(@oxygen)
I haae the same issue -- I have noticed that sometimes (especially when using 3mf files from others) that my Z value is not honored (and that the nozzle scratches the PEI sheet with the first layer -- since I always print in the center of the plate I have a lot of scratches in the PEI...
Printing over them only results in that the printed part has markings from the PEI markings on the bottom (if this makes sense)
Stock MK4S with FW 6.2.6
Respondido : 19/03/2020 7:04 am
Robeena Shepherd
(@robeena-shepherd)
Posted by: @oxygen
Are you saying I could print over it and the printed part becomes an eraser? 😂
Respondido : 19/03/2020 8:45 am
Oxygen
(@oxygen)
NO, when I scrape it off the PEI sheet and print over it I can still see the lines from the previous print on the bottom of the new print
Respondido : 19/03/2020 8:56 am
Robeena Shepherd
(@robeena-shepherd)
Oh that's a shame! They sound like indents rather than marks. I'm not sure what mine are...
Respondido : 19/03/2020 8:59 am
