Slicing from Cura - won't display print preview or remaining time on printer display
Title mostly says it.
PrusaMini x Cura 4.11
I've been slicing more with Cura as I find the setting array and UI to be better. Having imported the files from here and setting up the remaining time option as best I could in Cura under Post Processing Scripts following this video.
This is an alright workaround and give me a time remaining that alternates in on the printers LCD display at intervals. However the remaining time section of the default printing screen still remains blank and I can never get a print preview of the stl to display on the screen when exporting from Cura. I'm not sure what to do and am wondering if others have found ways to fix either or both of these problems.
Respondido : 11/01/2022 11:59 pm
