Slice engineering Copperhead heat block
Has anyone swapped out their heater block for the one from Slice engineering? I like the design, looks like it'll make swapping nozzles and other maintenance easier.
Publié : 09/06/2021 6:08 pm
RE: Slice engineering Copperhead heat block
Yes. Most who move to the Mosquito do so because they want an easy single-hand removal of the nozzle. The problem with the copperhead is the same problem you will still get a rotation of the hotend with nozzle removal. The is especially at risk along the heatbreak.
Publié : 11/06/2021 10:53 am
