Silicone Socks
dogosforeverdad
(@dogosforeverdad)
Silicone Socks
can I use Silicone socks on my MK3s hotend
once in a while I get a glob in a print
Napsal : 15/03/2021 10:25 pm
Lichtjaeger
(@lichtjaeger)
RE: Silicone Socks
Sure. It's a V6 hot-end. You can find the official socks here.
Napsal : 16/03/2021 6:37 am
RE: Silicone Socks
@lichtjaeger
Or are those unofficial?
Napsal : 16/03/2021 9:53 am
RE: Silicone Socks
Sure you can. But if that happens frequently — and if you begin to think about using a sock, I assume it does — I’d try to identify the root cause (eg leaking filament etc).
Napsal : 16/03/2021 12:35 pm
Bob
 Bob
(@bob-2)
RE: Silicone Socks
If you're getting a glob in the print there's another problem and a sock won't fix it.  You many need to check your extrusion rate, the assembly of your hot end, or the age of your filament.
Having said that there are reasons to put a sock on your Prusa I3, I added one on mine when I was having problems with my part cooling fan cooling the hot end.
If you do add a sock be sure and perform PID tuning as it will change the heating and cooling characteristics of your hot end.  Prusa has the procedure here https://help.prusa3d.com/en/article/pid-tuning_2265
Cheers
-Bob
Napsal : 17/03/2021 1:26 am
