Set custom load distance
Hi everyone,
I recently had to install a new PTFE-tube on my Mini, and the spare tube I had around was just a bit shorter than it should be. So until my replacement arrives, I have to work with what I've got.
My question comes here: Due to the shorter tube, the filament rams into the hotend when loading, as the fast travel distance when loading is longer than my PTFE-tube can offer. Is there a way to adjust fast travel distance when loading in the firmware (or directly on the printer)? If not, I'll just have to load manually, as I'm a bit worried I might damage something when ramming into the hotend.
Thanks in advance 🙂
Opublikowany : 20/03/2023 6:45 pm
