Selftest / X-Axis failure -- Have yet to use my new printer 🙁
1337pete
(@1337pete)
I received and built a "self kit" of the Mini+.  After completion, I ran the selftest, which fails with:
The selftest failed to finish.  Double-check the printer's wiring and axes. Then restart the Selftest.
I've tried, I believe, all the troubleshooting steps I've seen in the forum (tighten this screw, loosen this screw, ensure the belt is taut), but I'm not seeing a change.  The following is the log file output to the flash drive.  Any help would be appreciated!!
SELFTEST START
printer serial: CZPX3121X017XC55246
X-Axis Started
fwd X-Axis @50 mm/s
1065 18040 0
1105 18040 0
1183 18021 246
1233 17799 362
1283 17550 398
1333 17300 400
1384 17046 404
1434 16797 422
1484 16547 424
1534 16298 428
1584 16049 392
1634 15800 386
1684 15550 378
1734 15301 372
1784 15052 374
1834 14802 410
1885 14548 414
1935 14299 408
1985 14049 426
2035 13800 420
2085 13551 384
2135 13301 378
2185 13052 368
2235 12803 372
2285 12554 374
2335 12305 412
2385 12055 414
2438 11791 408
2488 11542 410
2538 11292 428
2588 11043 424
2638 10794 426
2688 10545 390
2738 10295 384
2788 10046 366
2838 9797 368
2888 9547 362
2938 9298 400
2988 9049 402
3038 8800 420
3088 8550 424
3138 8301 388
3188 8052 382
3238 7802 384
3288 7553 358
3338 7304 360
3388 7055 398
3438 6805 400
3488 6556 418
3538 6307 422
3588 6057 424
3638 5808 380
3688 5559 382
3738 5310 356
3788 5060 358
3838 4811 360
3888 4562 398
3938 4312 392
3988 4063 418
4039 3809 422
4089 3560 416
4142 3295 418
4192 3046 420
4242 2797 376
4292 2547 370
4342 2298 364
4392 2049 356
4442 1800 350
4492 1550 394
4542 1301 390
4592 1052 408
4642 802 410
4692 553 404
4742 304 358
4792 55 352
4842 -195 344
4892 -444 328
4942 -693 304
4992 -928 304
length = 189.679993 mm
X-Axis Failed
SELFTEST END
Posted : 27/09/2021 7:29 pm
thrawn86
(@thrawn86)
rods
are those rods seated all the way?  190mm seems like a lot, mine bottoms out around 184
Posted : 28/09/2021 4:41 am
1337pete
(@1337pete)
re: rods
I noticed that 190mm number and thought it might be a culprit, but didn’t think to reseat the rods. I’ll do that tomorrow. Thanks for the thought!
Posted : 28/09/2021 4:45 am
