Ripple effect on outer skin
Alter3go
(@alter3go)
What can be the cause of these ripples?
ripples
Print settings:
0.2LH - 15% infill
35mm/s - inner perimeter
25mm/s - external
Your advice would be greatly appreciated.
Napsal : 29/01/2023 2:58 am
Hello
(@hello)
RE: Ripple effect on outer skin
What fillament at what temperature
Napsal : 29/01/2023 3:40 am
Alter3go
(@alter3go)
Hello3D Bicolor silk
Temp - 210
Napsal : 29/01/2023 9:23 am
Without seeing the 3mf project file impossible to diagnose with certainty. I've seen these ripples most often when the combination of wall thickness and extruder width leads to random gap infill inserted into the walls. You may be able to address it by turning off gap infill or using height modifiers to adjust extruder width.
Napsal : 29/01/2023 12:13 pm
Alter3go
(@alter3go)
I tried another print with another color filament but getting similar results.
I have attached the 3mf file.  You help is appreciated.
Posted by: @fuchsr
Napsal : 02/02/2023 6:37 pm
Hello
(@hello)
Try bump temp up a bit
Napsal : 02/02/2023 6:52 pm
