Revo micro - filament making long tail when changing filament
trondkla
(@trondkla)
Hi!
Just installed my Revo Micro and when changing the filament, a long tail is created from the nozzle towards the extruder. This does not come out and is stuck in the bowdel tube. I think this will be problematic in the long run.
I use Prusament JET Black PLA Refill.
What is this called, I found it hard to google because I couldn't find this phenomen, but it must be quite common. I think I saw it a couple of times on the standard prusa mini hotend.
PS: I have a Bondtech IFS Internal Filament Sensor Extruder too, which I think need some more estep calibation, since when I load the filament some clicking accurs becasue it try to load it for longer time than needed, but I don't think that is part of this problem.
long stringing coming out of nozzle when changing filamenet
Opublikowany : 25/09/2023 8:27 am
