Replacing PEI sheet on smooth spring steel sheet
sanslos
(@sanslos)
Are replacement PEI sheets available for the MINI/MINI+?
I've collected some pits in the PEI sheet (not enough glue when printing FLEX; way too much adhesion with ABS; etc.).  There appear to be replacement PEI sheets for other Prusa printers, but not the MINI/MINI+.
Publié : 14/01/2021 5:59 pm
RE: Replacing PEI sheet on smooth spring steel sheet
Hi Sanslos
If I were not in the UK
I could buy them off the Prusa Site
Search under Spring Sheet, or look in the accessories section (Even though it says Mk3....     I expect the etc, covers the Mini)
Regards Joan
Publié : 14/01/2021 7:00 pm
sanslos
(@sanslos)
Howdy @joantabb
Those are the actual spring steel sheets.  What I was looking for is just to remove and replace the PEI itself, like with this:
PEI-Ultem sheet
Publié : 14/01/2021 10:13 pm
No I don't see Mini Sized PEI Sheets, only Mk2 and Mk2.5/mk3 sized sheets.
You could cut either if these to fit the mini...
Similarly I couldn't find any PEI Replacement instructions for the mini, but the Mk2.5 / mk3 instructions should work
https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920
Publié : 15/01/2021 3:29 am
sanslos
(@sanslos)
I was thinking about getting the larger sheets and cutting them down, if that's what was available.  The process is fairly involved, it could be that I just decide that buying a new PEI covered steel sheet is a better approach all around 😊 The reason I haven't done that is that the steel sheet is still useful, it seems a waste.
Thanks for the information!
Publié : 15/01/2021 3:56 am
