Repetitive Hotend MINTEMP error
MikaM
(@mikam)
Hello!
My mini works rather ok after replacing half of the parts... but one thing still bugs me, and its the MINTEMP error. The hotend is at +10-11 celcius all the time, no matter if the room is at +30. Bed shows 20 or so.
To get the printer heating, I need to hold my hand around the hotend and let it warm and then start the print..
Is this something  that others have, or is it just my MINI
Opublikowany : 30/01/2020 8:03 am
jaydubblazer
(@jaydubblazer)
RE: Repetitive Hotend MINTEMP error
Sounds like a thermistor issue. Start wiggling wires and see if you can see it jump around.  Make sure you have all off the sensors seated in the board.
JayDub
Weened on MK3's at work, FrakenMini and MKs at home.
Opublikowany : 09/02/2020 1:51 am
