Repeated MINTEMP Bed errors
Scott Frazer
(@scott-frazer)
After several weeks of successful prints with my Mini, I'm now getting regular mintemp bed errors. Sometimes it will happen in the middle of a print, but more recently it's been during the first or second layer.
I've tried to get it to fail by moving the y axis around or wiggling the heat bed cable, but neither of those cause the issue.
Any ideas where I should look next?
Napsal : 18/01/2020 5:26 pm
Oliver Thomsen
(@oliver-thomsen)
RE: Repeated MINTEMP Bed errors
Take a look here: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pictures-say-more-than-a-thousand-words/
Seems to be the same problem.
Napsal : 18/01/2020 5:49 pm
jaydubblazer
(@jaydubblazer)
I spent two hours on chat yesterday troubleshooting the issue.  They are going to forward it to the engineers, to check out.
mean while I have had some luck by removing the control panel cover.  Doing this allows the cable to move a little bit more and seemed to decrease my faults.
JayDub
Weened on MK3's at work, FrakenMini and MKs at home.
Napsal : 19/01/2020 9:13 pm
Scott Frazer
(@scott-frazer)
Update: It was a broken bed thermistor cable (like the link Oliver posted)
Support sent me a replacement and I haven't had any more errors since it was replaced.
Napsal : 24/01/2020 4:58 am
jaydubblazer
(@jaydubblazer)
I think that is want my ended up being to.  My new bed will be here in Monday.
JayDub
Napsal : 24/01/2020 12:10 pm
