Reassembled hotend and now fan is acting up
Daniel
(@daniel-7)
As the title says and the videos display, my fan is acting up now and I don't know why.
Opublikowany : 10/09/2021 2:10 am
Daniel
(@daniel-7)
Update: I've narrowed it down to the far side of the bed so it seems like a wire is being pinched/pulled just right. So, until I figure it out completely, I will just avoid prints on that side.
Opublikowany : 10/09/2021 4:28 am
mrstoned
(@mrstoned)
Title here
Try moving the hotend to the far side, then give the cables just a tiny bit more slack outside the little clamp.
I had similar issue with the red heater wires touching the fan itself, grinding against it.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Opublikowany : 10/09/2021 4:31 pm
1 ludzie polubili
Daniel
(@daniel-7)
That was it, thank you!
Posted by: @mrstoned
Opublikowany : 10/09/2021 11:03 pm
mrstoned
(@mrstoned)
Titlespace
Glad it worked out.
It's sometimes the smallest annoyance that gets you 🙂
Opublikowany : 11/09/2021 7:35 am
