Random print stop mini+???
IIERIIKII
(@iieriikii)
Hello all, I will try to keep this short...
PROBLEM-printing will randomly stop. nothing suspicious when it happens.
It will maintain power,display,motors,210Cand60C.. ect..
I can pause/resume - it just returns to last point and does not resume printing.
Sometimes it comes with a "check print head and thermistor"
Sometimes all I do is clean the bed and hit re print and it will print out fine.
It seems completely random when,if it happens.
AND...........
*THIS IS HAPPENEING WITH 3 PRINTERS*
1 mini+kit
2 mini partial built
All stock except E3D revo6 prusa edition in all 3
Firm-4.4.1+4194
Boot-2.0.2
Buddy-1.0.8
thank you for any help
Also I should mention. Ive been running this setup for a while on all 3 machines and it happens about 30% of the time. AND it happens with the stock hot end?!?
This topic was modified 3 years temu 2 times by IIERIIKII
Opublikowany : 02/03/2023 10:57 pm
Zoltan
(@zoltan)
Member Moderator
RE: Random print stop mini+???
Does the printer die, or is somehow alive?
Were you able to see just before it stops?
I guess you did not have a chance to reproduce.
Does it alway end up in the same status?
Can you share the picture after it stopped?
Opublikowany : 04/03/2023 11:31 am
IIERIIKII
(@iieriikii)
Umm, Not trying to be rude.....did you even read my post? I pretty much answered all your questions? But thanks for trying 🙂
Opublikowany : 04/03/2023 5:35 pm
Hello
(@hello)
Picture would help of when it stops
Opublikowany : 04/03/2023 6:07 pm
Hello
(@hello)
Also did you download different firmware
Opublikowany : 04/03/2023 6:09 pm
IIERIIKII
(@iieriikii)
The display screens are normal when this happens so no need for a picture....
And yes I dl firmware etc as stated in op.
Opublikowany : 04/03/2023 6:22 pm
Hello
(@hello)
Photos of hotend and where it stops we normally ask for and if I'm not wrong I believe revo has there own firmware for these hotends
Opublikowany : 04/03/2023 6:28 pm
IIERIIKII
(@iieriikii)
the hotend looks normal, except a small amount of filament build up where it stops. Ill get a picture next time it happens.
Opublikowany : 04/03/2023 6:47 pm
René
(@rene-3)
Since your problem occurs on all three printers, three things could be going on.
1. a problem/bug in the firmware after flashing.
Download the firmware again and install it on one of your printers.
Check if the problem is resolved on that printer.
2. a corrupt gcode file.
Slice the file again
3. a bad usb stick.
Try another USB stick.
Opublikowany : 05/03/2023 12:48 pm
1 ludzie polubili
IIERIIKII
(@iieriikii)
Thank you! This is making sense...
Ive seen some mention of usb sticks before...going to buy some new ones. I will dl firmware again and flash 1 printer. I will see if that changes anything, if not then I will hope its in the slicing...will post results.
thank you
Posted by: @rene-3
3. a bad usb stick.
Opublikowany : 05/03/2023 5:21 pm
Lous van Wijngaarden
(@lous-van-wijngaarden)
Posted by: @zoltan
Does it alway end up in the link same status?
Nothing to worry just keep trying.
Opublikowany : 15/03/2023 3:31 pm
