PrusaSlicer not generating supports?
Bascule
(@bascule)
Even having disabled no support material for bridging, my model won't get supporting material here:
Napsal : 26/04/2021 1:05 pm
RE: PrusaSlicer not generating supports?
Please save your PS project (File>Save Project As).  Take the resulting .3mf file, zip it up and attach it here.  Must be zipped for the forum to accept the files.
The project will contain not only the model but all the settings you are using to slice with as well as any potential modifiers etc.  Basically its the best way to debug issues like these.
Napsal : 26/04/2021 1:56 pm
Matt HD
(@matt-hd)
Try: Expert - Printer Settings - Support -> unflag: Don’t support bridges
Feedback appreciated.
Napsal : 17/05/2021 1:45 am
depending on how it is configured, slicer won't place supports in obvious area due to angles involved. If selecting Enforcer Only, the angle that was set in the generate support fields is still valid. You have to allow generate supports, set the angle to something easy, like 45, then set enforcers only again.
Napsal : 17/05/2021 6:21 am
