Prusa Mini+ Upgrade (E3D Revo Micro) Article
Hi there,
as I have seen some interesting first posts for the new E3D Revo Micro I wonder if the older Mini (not the MINI+) will also be suitable for the upgrade? If not - what would be the steps to an upgradable version?
Thanks in advance
Marc
RE: Prusa Mini+ Upgrade (E3D Revo Micro) Article
The difference between the Mini and the Mini+ is just the SPINDA. Everything that is compatible with the Mini is also compatible with the Mini+ and vice versa.
You can stick to the e3D upgrade guide without any additional steps. But there are already alternative parts and mods online, which you may want to take a look at. (Including my parts.)
Thanks a lot for the speedy answer.
I was in doubt if there may is any hidden circumstance that would hinder the Revo Micro solution to work. Both Prusa and E3D just mention the MINI+ in their documentation. So then go and oder one.
Marc
