Prusa Mini not pausing on color change
Gbutton
(@gbutton)
I have a print loaded up in prusa slicer and I've added color changes to the commands.
First, I loaded it up through Octoprint and my first color change came and went without any kind of notification.
Second, I sliced it again then uploaded it through a USB directly to the machine and still no pause.
I'm trying again with the M600 command, but is there a setting or something that I'm missing? I'd love to print in multi color.
Napsal : 17/12/2021 5:04 pm
BogdanH
(@bogdanh)
RE: Prusa Mini not pausing on color change
what did you actually do, when you say you added "color changes" to the commands?
Changing color at certain layer is very simple in Prusa slicer: slice your print, then move top end of the vertical ruler down (next to window showing sliced object) and click "+" icon on the right side of slider -that will initiate color change during printing (parking head, unload filament, waiting for you to change filament, load it after you confirm and continue printing).
[Mini+] [MK3S+BEAR]
Napsal : 17/12/2021 8:02 pm
Gbutton
(@gbutton)
This was user error. I simply grabbed the wrong file, the one I made before adding the color changes in the slicer.
I opened the file in text editor, checked for m600, the one I used didn't have it, then when I ensured my new version did, it worked.
Napsal : 17/12/2021 8:14 pm
