Problems with z-axis test
Jannes
(@jannes)
Utenti
Hello,
i have trouble to calibrate the z-axis of the mini+. meanwhile i re-installed the firmware, i checked and lubricated all axes and the shaft. X- and Y- axis calibration works well. always the z-axis calibration fails. i adjusted the PINDA sensor 2 times, i also checked the sensor itself, it works.
The print head moves up and down as expected, the calibration seems to work well. finally it is always declared as "not successful"
Any ideas what could be the reason for the problem?
Thank you!
Postato : 01/09/2025 9:00 pm
1 persone hanno apprezzato
Win J.
(@win-j)
Utenti
RE: Problems with z-axis test
Answered on my thread with the same issue: https://forum.prusa3d.com/forum/postid/764597/
Postato : 16/09/2025 10:19 pm
Kenyiro34
(@kenyiro34)
its simple to fix Z-Axis ( normally printer got 185 for it) skip wizard go setting push the button wait 3sec go experimental menu and change z-axis to 191 and save it and you got problem solved
Postato : 08/10/2025 10:32 am
Jannes
(@jannes)
Utenti
Thank you a lot for your help! works!
Postato : 12/06/2026 2:08 pm
Jannes
(@jannes)
Utenti
Thank you!
Postato : 12/06/2026 2:09 pm
