Problems with z-axis test
Hello,
i have trouble to calibrate the z-axis of the mini+. meanwhile i re-installed the firmware, i checked and lubricated all axes and the shaft. X- and Y- axis calibration works well. always the z-axis calibration fails. i adjusted the PINDA sensor 2 times, i also checked the sensor itself, it works.
The print head moves up and down as expected, the calibration seems to work well. finally it is always declared as "not successful"
Any ideas what could be the reason for the problem?
Thank you!
Napsal : 01/09/2025 9:00 pm
