Problem extruding at second layer in my Prusa Mini
xinjia
(@xinjia)
Video: https://streamable.com/fl0brw
I have not been able to print with my Mini for a few days. The first layer does it well, but the second, when speed increases, begins to clack. I have disassembled the entire extrusion system, I have cleaned it, checked that everything turns and also the hotend: I have adjusted the 3 screws on the side, the PTFE tube is fine, there is no filament obstructing the nozzle neither inside the hotend nor inside the nozzle since I have cleaned with a needle.
The material I use is Prusament PLA Galaxy Silver.
The printing parameters I test are the default PrusaSlicer 0.2 Speed without any modification.
Respondido : 07/08/2020 8:33 am
SS220
(@ss220)
RE: Problem extruding at second layer in my Prusa Mini
I have found some prusament filaments that have glitter in them need either a little bit hotter temps or to print a little slower. This seems to especially be the case if the model has a lot of retractions.
Respondido : 07/08/2020 2:02 pm
xinjia
(@xinjia)
@stevensmith
I try with Filoalfa PLA Black with the same result. Im trying to print a simple calibration cube.
Respondido : 08/08/2020 9:55 am
Malcolm
(@malcolm)
Looks like on your second layer, the nozzle  is hitting high spots from your first layer. Your Z height might be too low, and creating ridges
Respondido : 08/08/2020 12:08 pm
