Printing using wifi (Prusalink) and recognizing filament in sensor
Renze
(@renze)
I am using the newest 4.4.0 firmware. Before I was using the betas of this 4.4.0 version.
I leave my printer with filament unloaded lots of times. When I send a code to the printer using Prusalink (wether it is directly in Prusaslicer or in the web interface) the printer just start without having filament present. It probes at 170degrees and then it starts printing.
Is this problem  known at Prusa?
Opublikowany : 03/12/2022 2:44 pm
RE: Printing using wifi (Prusalink) and recognizing filament in sensor
This is a user to user help forum. I think you're better off posting a bug report on the Prusa GitHub site to bring this issue to the attention of the developers.
Opublikowany : 04/12/2022 11:17 am
1 ludzie polubili
Zoltan
(@zoltan)
Member Moderator
@Rgb
Could you pls attach a short video?
Opublikowany : 11/12/2022 6:14 am
Renze
(@renze)
@Zoltan sure.
Opublikowany : 11/12/2022 1:17 pm
Renze
(@renze)
Somehow linking doesn't work. Lets try again:
https://forum.prusa3d.com/wp-content/uploads/2022/12/prusalink_sensor_error.mp4
Opublikowany : 11/12/2022 8:28 pm
Renze
(@renze)
@Zoltan I also reported it on GitHub: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/2822
Opublikowany : 11/12/2022 8:39 pm
