Printer status when pause not correct via API
Hello all, I was just trying to include my 3d printers alongside HomeAssistant and receive a notification to do the filament change when I realised the status retrieved does not correspond to the real one when it is paused. Pause is still false
By looking at the json info at http://[MY_URL]/api/printer, while printing on the left and paused on the right, this is what I receive:
I would obviously expect in line 13 to change from false to true when paused, however the only noticeable difference was the change in material and in the z-height (which makes sense). I think this is a firmware issue/bug that could be solved easily.
Anyone has any other idea of what could be happening or any workaround?
RE: Printer status when pause not correct via API
Sounds like something that you should report as a bug on their github page.
https://github.com/prusa3d/Prusa-Link-Web
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
