Printed Directly on Heatbed - is it ruined?
bill2009
(@bill2009)
I accidentally ran a print without the steel sheet and the nozzle scraped the heatbed pretty badly.  I was hoping it wasn't fatal but now it wont heat past about 44 degrees.  Do I just buy a new one(ouch)?
Best Answer by Henry:
You scratched down into the copper and probably shorted out one or more heater elements, so yes it probably needs to be replaced.
Este debate ha sido modificado el hace 3 years por bill2009
Respondido : 05/05/2023 7:51 pm
Henry
(@henry-6)
RE: Printed Directly on Heatbed - is it ruined?
Respondido : 05/05/2023 10:38 pm
1 les gusta
Shushuda
(@shushuda)
It definitely needs to be replaced if the copper got damaged.
Also inspect the nozzle for damage, especially if you're using brass. You might have to replace it as well. I see it ran over a screw, so I assume the tip is damaged now.
Respondido : 06/05/2023 5:47 am
1 les gusta
bill2009
(@bill2009)
ok thanks - i'll order them today.
Respondido : 06/05/2023 10:59 am
