print fan failure
sllimj
(@sllimj)
print fan failure
I started to have issues with print quality, I ran a system check and Print Fan failed, I put a new one in and it still fails.
if I swap the print fan and the cooling fan connection the print fan works fine and the cooling fan doesn't work. proving fans work fine. I have checked Voltages and on start up the green LED comes on and voltage is 5v for a few seconds then goes away, that seems normal  but fan isn't coming on. During a print I can go to settings and turn Fan to 255 and again the Green LED blinks but fan fails to run.
hard to believe the 'Buddy" is bad, and I just had to buy a LCD because of an Encoder failure.
hoping I can get a some  incite to troubleshoot this.
thanks
Respondido : 12/10/2022 10:20 pm
Miembro
RE: print fan failure
I would contact support via the chat.
Respondido : 12/10/2022 11:45 pm
As Chuck said. Support is one of the reasons you've paid the big bucks for a Prusa.
Respondido : 12/10/2022 11:49 pm
sllimj
(@sllimj)
I will do so
thank you for quick reply
Respondido : 12/10/2022 11:57 pm
