[Résolu] Print Errors / Artifacts
Konsti93
(@konsti93)
Hi everyone,
I started printing this Screw Bit case from Thingiverse: http://www.thingiverse.com/thing:2920911
Unfortunately I started seeing random artifacts/print errors. The model was sliced with the latest version of PrusaSlicer 2.3. Today I tried again, this time using PrusaSlicer 2.3 Beta3 release but still got the same artifacts.
They do not show up in the gcode viewer. I seem to have the latest firmware installed in the Mini.
Here is the gcode file if it that helps: https://www.icloud.com/iclouddrive/06aKZQ9Smg4nkjLb10YXwCidw#bit-lag%5F0.2mm%5FPLA%5FMINI%5F3h45m
Publié : 20/01/2021 10:30 am
torbenberger
(@torbenberger)
RE: Print Errors / Artifacts
i get the same errors occasionally on my prusa mini, it seems to happen on "inner" circles or holes that have slight slope or roundness to them, like your thread or on the prusa screw and nut example.
Publié : 21/01/2021 8:54 am
torbenberger
(@torbenberger)
this has been marked as solved.. but how was it solved? @OP did you find a solution to your problem?
Publié : 26/01/2021 9:32 am
