Preview truncates part of 3D editor view
butchalline
(@butchalline)
This is a small frame 1mm thick.  My setup (using Prusa slicer 2.2.0) is this:
The editor view shows this:
and Preview shows this:
The printer prints only 3 sides of the frame instead of the desired 4 sides...why?
Posted : 08/11/2021 5:04 pm
mrstoned
(@mrstoned)
RE: Preview truncates part of 3D editor view
My guess will be that the thin line is too narrow to print normally.
Try enable Detect thin Walls, or if you have access to the model-files, try increase the thickness of the wall.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Posted : 08/11/2021 5:25 pm
butchalline
(@butchalline)
Thank you mrstoned.  Detect thin walls worked fine for me.
Posted : 16/11/2021 7:30 pm
