Powder coated build plate damaged
tobimai
(@tobimai)
as you can see in the attached picture, the powder coating of my textured build plate is "falling off". It kinda sticks to the bottom of prints sometimes.
I will probably get a new one, but I would be interested if something I did caused that, as the plate is pretty new (like 2 years, but mostly printing on the other plate). Distance to build plate is fine, prints release very easily (usually pop off by themselves) and I use 99% Isopropanol and paper towels for cleaning off fingerprints.
Best regards
Tobi
Opublikowany : 09/12/2024 9:14 pm
jsw
 jsw
(@jsw)
RE: Powder coated build plate damaged
Yeah, it looks like it's literally falling apart.  I have not seen anything like this.
I have one that's 4 1/2 years old and it still prints quite well.  I do like the textured surface that it gives.  I've tried finding a similar build plate for an Ultimaker printer and can't find one that will drop right in and work.
Posted by: @tobimai
Best regards
Tobi
Opublikowany : 10/12/2024 3:31 am
This looks extreme but then again, the sheets are consumables. I had one or two sheets that looked similar, mostly when I forgot to put glue stick on for TPU prints, or with PC.
Opublikowany : 10/12/2024 8:17 am
