Post print parking position suddenly on the print bed
Jeremy
(@jeremy-6)
I have been printing with my mini for a couple years now and suddenly the print head parks at Z=0. So far I've manually positioned my prints so there's no clash, but I would prefer to have it park above the tallest layer like it used to.  I checked the end Gcode (prusaslicer 5.2.2) and everything looks OK to my untrained eye, but I hope someone here will be able to confirm and to help me solve the issue:
G1 E-1 F2100 ; retract{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F720 ; Move print head up{endif}G1 X178 Y178 F4200 ; park print head{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)} F720 ; Move print head further up{endif}G4 ; waitM104 S0 ; turn off temperatureM140 S0 ; turn off heatbedM107 ; turn off fanM221 S100 ; reset flowM900 K0 ; reset LAM84 ; disable motors; max_layer_z = [max_layer_z]
Respondido : 20/06/2023 1:15 pm
RE: Post print parking position suddenly on the print bed
What firmware version are you running on the mini ?  Theres a known issue from quite a few versions back that was fixed.  It caused exactly the issue you describe.  Fixed by updating the firmware.
For example https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/print-head-collides-with-print-after-printing/
or https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/after-finishing-the-print-the-nozzle-parks-itself-in-the-upper-left-corner-of-the-bed-completely-squashing-the-print-in-that-area/
or https://forum.prusa3d.com/forum/prusaslicer/prusaslicer-2-5-0-mini-printer-ends-by-diving-into-bed-why/
Respondido : 20/06/2023 5:37 pm
1 les gusta
Jeremy
(@jeremy-6)
That fixed it, but it's odd that it suddenly started without me having done anything. On the other hand, I'm suddenly getting show stopping amounts of stringing, where I got almost none an hour before with the same filament and print settings, but with the old firmware. I guess I have to completely re-optimize everything on the new firmware?
Respondido : 22/06/2023 1:03 pm
