Possible to print test line after colour change (before printing)
3D_MD
(@3d_md)
I have printed a couple of objects where I manually enter a colour change in PrusaSlicer for the last few layers (to accent my objects).
However, each time I do this, the first few seconds of extrusion is not perfect since the hotend has filament hanging out of it.
After a colour change, is it possible to perform a "line" of extrusion on the print bed, adjacent to my object, before the printer goes back to the object itself? Similar to the test line that starts each print. Thank you.
Publié : 12/12/2021 5:54 pm
1 personnes ont aimé
Yes, in theory, you could write some custom gcode but you must make sure to move the extruder to a clear area to avid crashing your print.
There is another way.
When making the colour change first reply No to the color check question to trigger a longer purge, DO NOT REMOVE THE PURGE YET.
Grip the longer purge extrusion (with pliers if a hotter print) and answer Yes to the second color check question; only when the print head moves away do you pull away the purge and you should get all of it.
Publié : 13/12/2021 12:42 am
3D_MD
(@3d_md)
RE: Possible to print test line after colour change (before printing)
Fantastic. Thank you for the reply!
Publié : 13/12/2021 2:49 pm
JoesTinman
(@joestinman)
You can also add a small box to the right top of your model and use that as a wipe tower. Make sure in prusaslicer that the box is hit first after a color change.
Publié : 15/12/2021 8:55 pm
