PLA stringing
Seite 2 / 2
RE: PLA stringing
Much better.  Stringing like that is usually either due damp filament or to printing too hot.
Sometimes it is a symptom of a damaged nozzle - if you scraped the nozzle into the heatbed while setting up for example.
So look up threads here about drying filament.
If that doesn't help, please come back here.
Veröffentlicht : 21/05/2021 11:53 am
Mitglied
RE: PLA stringing
@mick-3
It is nto you settings.  Like posted above, try drying the filament or adjusting the temperature.
Veröffentlicht : 21/05/2021 12:34 pm
Mick
 Mick
(@mick-3)
RE: PLA stringing
Changed the nozzle now getting blobs and strings at a range of temperatures from 190 - 220. As an engineer I am struggling to understand the logic. Small changes in one variable at a time would be my approach but which one first? I still can't believe it is moisture as both filaments straight out of the packet have produced rubbish results but I will now bake my spools before trying again.
Thanks
Veröffentlicht : 22/05/2021 10:24 am
Mitglied
RE: PLA stringing
@mick-3
Blobs are usually a leak.  Check to see if there is molten plastic leaking between the nozzle and heatblock.
Veröffentlicht : 22/05/2021 10:42 am
Mick
 Mick
(@mick-3)
RE: PLA stringing
I put the original nozzle back in there is now no gap and no oozing but still blobbing and stringing.
Thanks
Veröffentlicht : 22/05/2021 12:11 pm
Mick
 Mick
(@mick-3)
RE: PLA stringing
Trying to find a suitable temperature tower for the mini any ideas? They all seem to be for the MK3.
Ta
Veröffentlicht : 22/05/2021 12:33 pm
Mitglied
RE: PLA stringing
Temperature tower
You do not need to have a true tower.
I often use:
https://www.prusaprinters.org/prints/26509-retraction-test
or
https://www.prusaprinters.org/prints/35313-calibration-cube-test-setting-plus-overhang-print-/files
I just print them over and over until I get the temperature, cooling, and retraction.
Veröffentlicht : 22/05/2021 12:39 pm
Mick
 Mick
(@mick-3)
RE: PLA stringing
Thanks again I will try those after the present print completes which looks much better. The tower I tried to print only printed at 215° even for the 225° first layer, I think you need to modify the g-code to change temp for each layer. The problem during the nozzle change was as you suggested a gap caused by a different length of thread on the nozzle. Changing back to the original I could close the gap fully and eliminate oozing and blobbing. You have been most kind with your time and patience thanks once again I have been a little frustrated to say the least.
M
Veröffentlicht : 22/05/2021 2:37 pm
Mitglied
RE: PLA stringing
@mick-3
I suspect you are correct.
Veröffentlicht : 22/05/2021 3:26 pm
Mick
 Mick
(@mick-3)
RE: PLA stringing
Finally a decent print little or no stringing no blobbing. Retraction set to 3.4 lift 0.15, 0.4 nozzle, 0.15 layer height using Prusament Azure blue.
Many thanks once again to all who helped me get there.
Veröffentlicht : 22/05/2021 5:22 pm
Mitglied
RE: PLA stringing
@mick-3
Pretty nice print!
Veröffentlicht : 22/05/2021 10:54 pm
Mick
 Mick
(@mick-3)
RE: PLA stringing
PLA seems pretty much sorted now, having similar problems with PETG any advise on that front?
Thanks Again.
Veröffentlicht : 30/05/2021 1:56 pm
Seite 2 / 2
