[Rozwiązany] Password for color change
Alexandre
(@alexandre)
Hello,
I tried for first time to print with 2 colors with prusaslicer and my mini+.
With prusaslicer, I selected "Change color (M600)" on the right of the sliced print. (Easy) 🙂
When printing, the mini+ stops at the googd layer, rings and asks if the new filament is inserted. (it's perfect)
Then I press "Continue". Mini displays "Password", nothing else. Impossible to do anything. I only can restart the mini+.
I' tried 3 times, always the same result.
Have you any advice ?
Thanks a lot!
Opublikowany : 20/01/2023 3:01 pm
Alexandre
(@alexandre)
RE: Password for color change
this subject is always created here :
https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/my-prusa-mini-ask-me-a-password-for-every-filament-change-since-updating-the-firmware/
I try to remove filament from sensor 🙂
Opublikowany : 20/01/2023 3:09 pm
