Parking function while loading filament tries to go beyond Z upper limit
Jack
 Jack
(@jack-5)
When you start the Load filament procedure the first step is the parking function where it raises the Z axis up a bit: I've encountered the problem when the Z axis was raised enough such that while parking it tried to go beyond the upper limit and didn't try to stop but continued trying to raise the axis.
Is it a known software issue?
First day of using my new MINI+ and already found a bug, I'm amazing at founding them
Posted : 26/03/2021 7:14 pm
Walter Witt
(@walter-witt)
RE: Parking function while loading filament tries to go beyond Z upper limit
My printer has always done this, and I'm really quite surprised it hasn't been fixed yet. The Stepper drivers clearly can tell when they've been stalled, yet the Z axis never uses this info to prevent it from running into the top. It hasn't caused any actual problems for me though, other then the unpleasant noise.
Posted : 28/03/2021 5:39 am
@walter-witt
the Z axis uses a screw thread rather than a belt, which is less responsive to Stall Guard
There are a lot of Parameters that you can use with M600....
https://marlinfw.org/docs/gcode/M600.html
I believe you can stop it from rising on filament change using some of these parameters
Posted : 28/03/2021 1:18 pm
