Parking after print strangeness
shags72
(@shags72)
3 prints sliced today and had 2 of them park here the first one was normal somwhere above the part, approximately and inch, and back corner but the last 2 where shown. I haven't updated anything lately and certainly not today. I have been printing things recently and no problems like this. Any ideas? Thanks
Napsal : 12/09/2022 2:29 am
RE: Parking after print strangeness
Can you upload the 3MF file so we can see your settings?
Napsal : 12/09/2022 9:37 am
Tim Heuvel Van Den
(@tim-heuvel-van-den)
I have the same problem since 3 days. 8 programs made with the purse slicer version 2.5.0, the first 3 programs without problems then it drops to z0.25 at the end with the nozzle. I can't find this action anywhere in the G-code file. it says as it should be that he has a small retract and after that an extra retract. Added the G-code file in the attachment. Print 7 - Front Wheelhouse - 0.15mm_PLA_MINI_0.15mm_PLA_MINI_12h51m
Napsal : 12/09/2022 10:27 am
Have you reported the issue on the prusaslicer GitHub?
Posted by: @tim-heuvel-van-den
Napsal : 12/09/2022 10:34 am
Tim Heuvel Van Den
No, this is the first thing i say about it after I can't figure it out myself. I see noting in the G-code, it seems to me that something in the printer go's wrong.
Napsal : 12/09/2022 11:25 am
shags72
(@shags72)
Here is the last one. I had not updated firmware for sometime but what is strange is that I hadn't even done the update to prusaslicer either. So as it sat, it was good for weeks if not months at its current state of software/firmware. I updated the firmware and ran a sliced part from last night and it ran fine today. I don't see anywhere in the code to go to Z.25.
Napsal : 13/09/2022 1:53 am
shags72
(@shags72)
Are you updated on firmware to 4.3.4? I did and it fixed it at least in one print.
Napsal : 13/09/2022 1:55 am
Tim Heuvel Van Den
I saw a post on facebook and tested it last night. I was able to run 1 print and it worked fine again. I find it strange that I haven't had any problems for a year and suddenly this happened. But for now it seems resolved.
Napsal : 13/09/2022 5:46 am
This is a known issue https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/extruder-back-to-headbed-at-the-end-of-the-printing/
I am glad you have discovered the fix which is to update your printers firmware.
Napsal : 13/09/2022 6:31 am
1 lidem se líbí
shags72
(@shags72)
Thanks all! I sliced and printed another print and all seems well.
Napsal : 18/09/2022 8:20 pm
