Original disk image USB stick Prusa Mini+
DoctorJack
(@doctorjack)
My stick became corrupted and all files are gone. Any way to download the STL files as well as other info and reload it?
Napsal : 07/09/2023 2:40 am
_KaszpiR_
(@_kaszpir_)
RE: Original disk image USB stick Prusa Mini+
If your pendrive is corrupted you could try data recovery - some companies do it, but usually price is super high.
You would have to find source files you used for making the prints (.stl or .3mf files over the internet etc) then slice them again to generate .gcode files and write it to new pendrive. Maybe you have cloud backup?
Then reattach pendrive to the printer and you could use it.
That's why people recommend to make backup of the source project and gcode files, because projects disappear from the internet.
Napsal : 07/09/2023 7:14 pm
René
(@rene-3)
Here you have the original contents of the usb stick.
Original mini
These are only the g-code files.
Also on the original usb stick is a folder called MANUAL_KIT containing the assembly instructions in various languages.
MINI+_assembly_108_EN
Napsal : 07/09/2023 10:37 pm
Walter Layher
(@walter-layher)
For data recovery I can recommend the free open source software Photorec. I was able to recover the files from several unreadable SD cards with this and made some people from my photo group very happy. It is available for all OS platforms.
Napsal : 07/09/2023 10:51 pm
