Not booting without usb stick on anything higher that 6.0.4
NEO
 NEO
(@neo-3)
I have recently got a printer in for repair. It didn't read the usb stick without restarting, I found that would probably would mean that it is a software issue so I looked what software it had and it had software 6.0.4 and weirdly bootloader 2.4.1, I didn't think much about it and updated the software to 6.2.4(the latest) it booted and when i removed the usb stick it still said that it was there and if I pressed print it would crash. When I tried to restart the printer without the usb stick installed it would go past the bootloader and get halfway stuck loading, if the usb was present before restarting it would continue booting and showing the software version. Does anyone know if this is a bootloader issue?
Napsal : 16/05/2025 8:09 am
NEO
 NEO
(@neo-3)
RE: Not booting without usb stick on anything higher that 6.0.4
I have just tried software 6.0.0 and it would boot without issue without a usb and when I would plug it in it would recognize the stick but when I pull it out it would still say that there is a usb stick. I have also tried the firmware's: 6.2.0, 6.1.2, 6.0.4, 4.4.0. Also does anyone know how I could reinstall the bootloader? I can only find bootloader 1.0.0 and not anything newer like 2.3.5
Napsal : 16/05/2025 1:43 pm
