Not accepting g-code from thumbdrive 🙁
Jeff Scott
(@jeff-scott)
I just updated my prusa mini to the most recent firmware and it doesn't always stay connected to prusa connect. My printer is turned on and hardwired via ethernet but my app and computer both say the printer is off line. So I exported a g-code from Prusa slicer to a thumb drive and got on my mini: "Warning the G-code isn't fully compatible G-code not sliced for input shaping."
What is going on? Is the firmware update a problem? I updated to Firmware 6.4.0? Thanks for any help 🙂
Opublikowany : 03/03/2026 1:24 am
It's telling you that it is running Input Shaper enabled firmware but you are producing g-code that is not using it ... have you downloaded the latest Printer presets to match..?
Opublikowany : 03/03/2026 5:21 pm
Jeff Scott
(@jeff-scott)
RE: Not accepting g-code from thumbdrive 🙁
I don't think so. I will try redo the presets tonight.
Opublikowany : 03/03/2026 8:07 pm
