[Rozwiązany] Need Extruder PTFE tube
jonah_mweather
(@jonah_mweather)
My PTFE tube from extruder to hot end was cut too short and I need a new tube, I have the olives and swivel nuts that come in the package on prusa's site, but if there is a way to avoid the $15 just to ship the $2 part to the US, I would like to do that. In case it might be important, I do still have the small spare piece of PTFE that came with my printer.
Best Answer by karl-herbert:
Posted by: @jonah_mweather
I have equipped my printers with these PTFE's: https://www.captubes.com/
4/2 is a standard size and available almost everywhere. I would not recommend other materials, e.g. PVC or PU.
wbr,
Karl
Opublikowany : 03/07/2021 4:18 pm
BogdanH
(@bogdanh)
RE: Need Extruder PTFE tube
I'm more than sure that you can find PTFE tube closer to you.. just search for PTFE tube with outer diameter of 4mm and inner diameter of 2mm (for 1.75mm filament).
[Mini+] [MK3S+BEAR]
Opublikowany : 03/07/2021 6:39 pm
wbr,
Karl
Opublikowany : 03/07/2021 7:48 pm
jonah_mweather
(@jonah_mweather)
@karl-herbert
I ordered the 4/1.9mm, will that work or do I need exactly 2mm
Opublikowany : 05/07/2021 5:45 pm
@jonah_mweather
is that for the short tube or the bowden?
the proper size is 2mm for all mini pipes.
the short hot end liner should be ok at 1.9mm
the bowden may be a bit tight especially where it goes through the olives
Opublikowany : 05/07/2021 7:01 pm
FreestyleEngr
(@freestyleengr)
Penny Parts for your thoughts...
This is why I recommend ordering spare parts when ordering anything from Prusa3D, you'll never know when something random happens - like a cat who likes to gnaw on cables and PTFE  tubes, or cat hair getting caught in a fan and destroying it.
Order the following the next time you order anything:
1. Prusa i3 Mk3 Feet (4x - you'll thank me later, they work better than the Prusa Mini foam pads and fit in the extrusions nicely, you can cut the top off of one and glue it under the Z axis)
2. Spare Hotend PTFE Tube
3. Spare Bowden Tube Assembly
4. Spare fans (both of them)
5. Prusa Printer Rod Grease - it's pretty cheap and it'll keep you from replacing rods every 200-400 hrs
All the above will cost far less to buy beforehand than frantically looking for spares at the last minute. There are plenty of suppliers who would gladly overnight you parts for a very large markup.
Opublikowany : 18/07/2021 10:19 pm
