[Risolto] Motor getting stuck when unloading filament
qwertzui11
(@qwertzui11)
Hi there!
So when I try to unload the filament, everything gets stuck and the motor gets very loud.
This only happens, when I unload. NOT when I load.
So I opened the extruder pully. But everything was clean and properly set up.
When I remove all gears inside, the motor works just fine and has great power. But when I add the gear and wiggle it, it gets stuck again. I added a video.
Any ideas what the issue could be?
https://www.veed.io/view/31317ce7-34d1-41a5-b449-eade7f098cc2
Cheers
Markus
Postato : 22/10/2022 12:47 pm
Zoltan
(@zoltan)
Utenti Moderator
RE: Motor getting stuck when unloading filament
Could be a damaged gearbox, contact the support.
Postato : 22/10/2022 4:19 pm
qwertzui11 hanno apprezzato
qwertzui11
(@qwertzui11)
Done.
The support was very helpful. And send me two new gears.
https://www.prusa3d.com/product/extruder-drive-gear-motor-pinion/
https://www.prusa3d.com/product/extruder-driven-gear-filament-spur/
I changed them and now everything works fine! 😍
Postato : 04/11/2022 8:12 am
Zoltan
(@zoltan)
Utenti Moderator
Postato : 04/11/2022 2:43 pm
