Mini+ Powers off before doing calibrations print
arnmac
(@arnmac)
Mitglied
I have a Prusa Mini+ with the latest 6.4.0 firmware. I recently had to install a new hotend. The printer had sat for several months unused. After replacing the hotend I attempted to do a bed calibration print. The hotend heats up correctly, then the bed gets to 50 degrees and the machine shuts off entirely. I have to remove the power supply or disconnect it from the wall before the machine will turn on again. The machine is able to do the bed point calibration. I can individually head the hotend to 245 and I can head the bed to 65 but not at the same time. I have checked the fuses and they are still good. I also ensured everything is plugged in.
I immediately thought it was a problem with the power supply and purchased a replacement from Printed Solid. I received it today and when I did my test calibration print it shut off. So the problem is not the power supply. Not sure to check next to get my mini+ working again.
Veröffentlicht : 14/04/2026 2:31 am
arnmac
(@arnmac)
Mitglied
RE: Mini+ Powers off before doing calibrations print
Just a note the "test calibration" I mention is the First Layer Calibration.
Veröffentlicht : 14/04/2026 4:11 am
