[Risolto] Mini Nozzle dragging through print?
Jlainton
(@jlainton)
Morning all,
I have a mini that has been a bit of a rockstar for the last 3 weeks, I've had a lot of fun with it.
Yesterday, when I was changing filament, I needed to do a cold pull, which I fine, but since then I have trouble with the nozzle as it comes back on the X axis towards the main mast (moving left to right). It appears the nozzle is dragging through the print, which clumps up, and causes issues. Ive done first layer calibration, and it seems good. I have adjusted both ways and it doesn't seem to be the issue.
I tightened all the parts I can see thinking the base and the mast are off kilter, and nothing seems out or even loose.
Im at a bit of a loss, thoughts anyone?
Best Answer by René:
It is possible that due to the cold pull the Z construction has changed in relation to the Y axis.
Perform the following steps XYZ calibration
And then do a first layer calibration.
Postato : 10/03/2023 12:27 pm
René
(@rene-3)
Postato : 10/03/2023 3:48 pm
Jlainton
(@jlainton)
RE: Mini Nozzle dragging through print?
This.
Wow, was it out of whack.  Printing like a dream again.  Thank you.
Postato : 10/03/2023 11:15 pm
