MINI Hotend Grub Screw
Ethan
(@ethan-3)
Hey Y'all, I was thinking of getting a capped replacement for the hotend grub screws for my Prusa MINI, however, I can't seem to find the size.  If anyone knows the size or the name of the screws, I'd appreciate it if you let me know.  Thanks!
Napsal : 17/10/2021 1:43 am
BogdanH
(@bogdanh)
Wall thickness of heatsink (at heatbreak) is 3.25mm and so M3x4 screw would be needed. I think 5mm length would be good too (grind it if needed).
[Mini+] [MK3S+BEAR]
Napsal : 17/10/2021 6:43 am
Sugarlumpz
(@sugarlumpz)
RE: MINI Hotend Grub Screw
These are perfect: https://www.amazon.com/dp/B07B6TTHN3. They are M3x4, and they take a 2mm hex head/allen wrench. They also practically vanish next to the heatsink.
Napsal : 29/07/2022 4:36 pm
2 lidem se líbí
