Mini Firmware Will Not Update
IAppearMissing
(@iappearmissing)
I am at my wit's end here as to why the Mini firmware will not update, and I am hoping that somebody can help me out. My Mini is currently on 4.0.5 and I am trying to get it updated to 4.1.0. I have download the firmware both directly from Github and from Prusa's driver website (separate sticks and separate attempts. I have reset it with the USB in and tried from within the menu, nothing is working. Other then this issue it is brilliant and I love it, please help.
Respondido : 28/07/2020 11:01 pm
Malcolm
(@malcolm)
RE: Mini Firmware Will Not Update
Do you mean it is not giving you the option to flash the new firmware? Try this: as you reset the Mini with the USB in, when the first screen comes up, double click the scroll wheel. This is how you get it to recognize a previous version of firmware (if you wanted to downgrade), but maybe it will help in your case.
If that fails, maybe roll back to an older version (or re-flash 4.0.5) then try and update again.
Respondido : 29/07/2020 5:29 am
1 les gusta
Gordon W
(@gordon-w)
https://help.prusa3d.com/en/article/firmware-updating-mini_124784
Respondido : 29/07/2020 7:54 am
Mick
 Mick
(@mick-3)
Same issue red screen will not flash from any stick to any version
Respondido : 17/11/2023 6:24 pm
René
(@rene-3)
This may have to do with the firmware version, which is now on your mini.
If it is lower than version 4.4.1 then you cannot flash the latest updates.
You will need to install version 4.4.1 before you can continue updating.
Respondido : 19/11/2023 11:38 am
2 les gusta
cormachm
(@cormachm)
Miembro
@rene-3 thank you, this worked for me!
Respondido : 27/11/2023 9:47 pm
Ben Kadavy
(@ben-kadavy)
Miembro
I am currently running the 4.4.1 firmware. I have been unable to get the printer to update to 5.1.0. I have tried multiple USBs. It won't even revert to any other version I try to flash to it. Could it really just be the USBs? The printer can see the USBs and print from them, but no update ever starts when I reboot. I have checked the setting too on the Mini FW Update Setting.
Respondido : 06/12/2023 3:02 am
deesar
(@deesar)
Miembro
Can anyone help? Which .bbf file in the 5.1.0 firmware zip is english? OR do all six unzipped files get loaded onto the usb for the final step in this final step of the mini v4.1 to v5.1 firmware update!?
Respondido : 08/12/2023 2:36 am
René
(@rene-3)
Posted by: @deesar
The five files are each bilingual.
CS = Czech language
DE = German language
ES = Spanish language
FR = French language
IT = Italian language
PL = Polish language
EN = English language
So if you wish to use English menus, you can put one of the six files on your usb stick.
Respondido : 08/12/2023 11:55 am
1 les gusta
George Carpenter
(@george-carpenter)
Miembro
Thanks you so much!!!  This worked for me.
Respondido : 20/12/2023 2:15 am
InsaneDragon
(@insanedragon)
Miembro
I fixed my issue, I went from 3 something to 5.1.0. on my Mini
You have to update in steps. I would do each one, as some have a boot loader update. As mine would not auto update, I pressed the reset button and spam clicked the selector nob, and got it to update. Took about 30min to do all, but was well worth it
Respondido : 30/12/2023 2:48 am
doetscn1
(@doetscn1)
Miembro
All,
Thank you for this thread!
I was way behind in my Original Mini Firmware updates, so I spent a bunch of time trying to get updates to work over the last few days using info I found here.
Nothing I did would help ... I did learn to click the scroll wheel during start up. Message said Firmware was not compatible.
The FIX ... I was using my Windows 11 machine to download and unzip the files, after sleeping on it I thought I would try my old Windows 10 machine to download and unzip (extract).
That did it.
As suggest here I loaded all the Firmware updates sequentially (was at 4.3.4 now at 6.0.1 with a few bootloader updates as well 1.10 to 2.3.4)
I hope this helps other.
Respondido : 13/08/2024 5:01 pm
Don
 Don
(@don-10)
Miembro
I just wanted to express my gratitude for the links and guidance in this post. I was on the verge of frustration, but this helped me just upgrade from 4.3.1 to 6.1.2. Thank you!
Respondido : 20/09/2024 5:55 am
n n
 n n
(@n-n)
Miembro
A little late, but I found a fix to my issue. I update to 4.4.1 but still couldn't update to the latest. If you have an older .bbf version in your USB root, it wont read the newer version. I just deleted every .bbf file in the USB except the one I wanted and that fixed it.
Respondido : 14/11/2024 5:18 am
rarefied
(@rarefied)
Miembro
I had this issue and the only way I got it to work after 30 mins of trial and error was to not unzip the file and instead copy direct to flash drive. I've always been taught to extract from a zip first so I'm very confused...but glad its working now.
Respondido : 26/02/2025 8:27 pm
DeathClawz
(@deathclawz)
Miembro
I've been having the same problem and finally figured out the issue. I updated from something like 4.0.5 to 4.4.1 to 6.2.2. The printer didn't recognizing that the USB drive was inserted so it wouldn't even try to update. When the main screen showed it would say no USB; taking it out and back in allowed the printer to see it, but as soon as I restarted to try and update it would forget it again.
The solution was to start the printer and put the USB drive in as the bootloader is shown on the screen. It recognized it immediately and started updating to 4.4.1. For 6.2.2 I had the same issue and solution. So if you notice it's not showing the USB on startup, this might be your issue.
Respondido : 13/04/2025 5:09 pm
