mini firmware request for Filament menu actions: do not heat the print bed
Heat the print bed for Filament menu actions of Load, Unload, Change, Purge of an idle printer Poll is created on Apr 30, 2023
abrickshort
(@abrickshort)
Thank you.
Respondido : 30/04/2023 1:55 pm
RE: mini firmware request for Filament menu actions: do not heat the print bed
This is a user to user forum.  If you want firmware changes then that needs to be done on the mini firmware github repository.  Located https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
I do believe this request has been made multiple times already though.
Respondido : 30/04/2023 3:17 pm
abrickshort
(@abrickshort)
will do. Thank you for redirect to github.
Respondido : 30/04/2023 5:05 pm
jseyfert3
(@jseyfert3)
Posted by: @abrickshort
Thank you.
Specifically make it an option, not disable it. Because most of the time, if I am loading, unloading, or changing filament, it’s because I’m prepping for another print and I quite appreciate the bed is already mostly or fully heated by the time I’m done, since when starting a print you always end up waiting for the bed to heat if it’s not already heated. So this saves time.
Respondido : 01/05/2023 1:20 am
It's an option in the XL firmware, so hopefully it'll find its way to the Mini.
Respondido : 01/05/2023 11:03 am
2 les gusta
