MINI+ crashes after Firmware 5 update
I updated the firmware to 5.1.0-alpha1, and the printer freezes and crashes when trying to select a gcode to print in the printer interface. I noticed that shorter, smaller prints do actually print, but everything else crashes after selecting the file.
I'm somewhat new to this, so it's totally possible I updated the firmware incorrectly. I deleted the .bbf files and uploaded the latest .bbf file to the flash drive. Everything flashed and updated correctly, from what I could tell.
Any help you can give would be great. If you need more info, let me know.
Thanks!
Have you reported this on GitHub? The devs probably won't see it here.
RE: MINI+ crashes after Firmware 5 update
Wechselt mal den USB Stick und probiert noch einmal upzudaten.
Ah ok. Thanks!
Do you mean use a completely different USB stick?
Looks like it might have to do with files not in the root directory.
Yes, take a complette different USB stick, put the update on it and try again updating. This problem i had when I tried to insall the 4.4.1 firmware.
