MINDA probe failed
LordWhiteley
(@lordwhiteley)
MINDA probe failed
So after waiting months for my Mini to arrive, I find that the MINDA probe not working when I tested the assembled printer 🙁 The printer could not detect the heat bed and there was no LED lighting up on the probe.
So I have contacted Prusa Support, but after nearly 10 days they still haven't sent out a new probe.
Therefore, does anyone have the part number of the probe and the wiring to the 4-pin Molex connector (there are 3 wires). It might be quicker to make my own leaded probe up or buy one from a third party??
Thanks in advance
John
Posted : 20/02/2020 5:05 pm
RE: MINDA probe failed
Hi John,
I don't have access to a Mini,but here is a picture from the spares page
it appears to be wired similar to this Pinda cable,
with the exception of the white wire (thermistor), as use on the mk3 printer
I expect you could check this on your printer.....
whilst checking, make sure the cable is firmly installed and all wires are properly  inserted into the plug.
Posted : 20/02/2020 8:56 pm
the Minda is connected in the top right hand of the electronics box
viewed from this angle
Posted : 20/02/2020 8:58 pm
LordWhiteley
(@lordwhiteley)
RE: NINDA probe failed
Thanks Joan
Well it looks like wiring to the connector was incorrect!!!
I removed the pins and mirrored the connections and it now works perfectly ! So they were obviously wired up incorrectly in the first place??
- I wonder how many other people have been effected??
This post was modified 6 years ago 2 times by LordWhiteley
Posted : 20/02/2020 8:59 pm
Glad I could help John,
Posted : 20/02/2020 9:19 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi John,
thanks for the heads up and sorry for the issues, I'm already investigating this with our devs and production team.
Assembly manuals
/ Knowledge Base
Posted : 25/02/2020 11:08 am
Texy
 Texy
(@texy)
This is should of shown up on the test report print out supplied with the printer ?
Texy
Posted : 25/02/2020 12:54 pm
