maxed out at -2.00 Z axis offset, first layer calibration
AZ_TIM
(@az_tim)
Installed the super pinda in my Mini. doing the first layer calibrations. I'm down to a -2.00 Z offset and think I could go further.
I've hit the limit of adjustment. This leads me to believe my Pinda is not at the right height. perhaps I need to adjust it - I used the credit card method, maybe the card was too thick or too thin?  do I need to lower the Pinda - use a thinner card, or do I need to raise the Pinda - use a thicker card to get the additional negative (-Z) offset I need?
Thanks!
I'm not a mad scientist, I'm an angry engineer in training.
Opublikowany : 03/06/2021 6:03 pm
Baklin
(@baklin)
RE: maxed out at -2.00 Z axis offset, first layer calibration
If you want to go lower, you need to raise the PINDA.
Opublikowany : 03/06/2021 6:08 pm
AZ_TIM
(@az_tim)
@baklin
Thank you!  That's what I thought, but wanted to do a sanity check!
Opublikowany : 03/06/2021 6:13 pm
@Urb
 @Urb
(@urb)
Hi, had the same problem a few days ago, check the link for tips on solution!
https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/nozzle-height-adjustment-bottoms-out-mini/#post-452383
Opublikowany : 03/06/2021 7:09 pm
AZ_TIM
(@az_tim)
thanks for the reply, I will try raising the Pinda slightly.
Opublikowany : 03/06/2021 7:33 pm
