Magnetic Micro USB port cables?
Steve
(@steve-14)
I saw the micro usb cable from my Raspberry Pi to my Prusa Mini+ looked a little loose, and when I went to fix it, I broke off the micro usb port from the Buddy Board.  Yahoo.  I ordered a new Buddy Board, which I'm waiting on.
While I was trying to figure out a better way to prevent this from happening again, I saw that magnetic Micro USB connectors exist.  Basically, you plug in one end to the micro USB port, which stays there, and the other end is a magnetic cable connector which can detach.  Presumably this works in a similar way to how Apple's  MagSafe connectors work - bump the cable, and it releases.  This looks like the thing I want, because I sure don't want to break the micro usb connector off of another Buddy Board.
Has anyone here set something like this up?  Has it worked well?
Posted : 28/03/2023 5:59 pm
RE: Magnetic Micro USB port cables?
There are at least two types, 0ne has only two connections, for charge only, another has four connections for power and data
Posted : 28/03/2023 6:24 pm
